• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    ethor
    IRobotNodeCompatibilityDef API Example please
    98 Views, 3 Replies
    12-05-2011 10:32 AM
    I am trying to create compatibility properties for nodes using the API. I am not sure of how to use IRobotNodeCompatibilityDef. I am able to add the label and define its data but how do you use the  IRobotNodeCompatibilityDef methods to define master and compatibility nodes? Can you please provide a short example?
    Please use plain text.
    Product Support
    Re: IRobotNodeCompatibilityDef API Example please
    12-06-2011 02:01 AM in reply to: ethor
    by CompatibilityDef you can only get \ check compatibility created on model
    Dim VLabel As RobotLabel
    Dim VData As RobotNodeCompatibilityData
    Dim Vdef As RobotNodeCompatibilityDef
    'defining and assigning compatibility
    Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_NODE_COMPATIBILITY, "comp")
    Set VData = VLabel.Data
    VData.UZ = True
    Robapp.Project.Structure.Labels.Store VLabel
    master_node_number=123
    dim Bars as String
    Bars = "3 4 5" 'bars list to which "slave" node will ve assigned
    Robapp.Project.Structure.Nodes.CompatibleNodes.Set master_node_number, Bars, "comp"
    ' checking compatibility defined on structure
    Set Vdef = Robapp.Project.Structure.Nodes.CompatibleNodes.Get(1)
    aaa = Vdef.LabelName  'checking compatibility name \ label used in this compatibility
    bbb = Vdef.Bars 'bars list
    ccc = Vdef.Main  'checking compatibility main node number
    ddd = Vdef.Compatible ' checking compatible node number
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    ethor
    12-06-2011 07:29 AM in reply to: RG_Adsk
    Why is it nessicary to have a bars list. What if the nodes i want to "couple" are connected to shell/area elements? Or no elements at all?
    Product Support
    12-06-2011 07:47 AM in reply to: ethor
    Even in Robot itself it is not intended to create compatibility between FEs. If you know the trick you can do it.
    You can define compatibility between FEs node and bar it the way that main node will belong to FEs and slave node to selected bar(s)
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
