• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    StefanoPasquini6790
    Accepted Solution
    IMPORT AND EXPORT FROM ASD TO ROBOT
    387 Views, 4 Replies
    10-18-2012 08:51 AM
    Hi everyone, I have a problem with the import and export models from asd to robot. Last week I've uninstalled ASD2012, robot 2010 and robot 2011 from my pc and now I can't import or export any model.
    Anyone can say me how I can fix this issue without reinstall all?
    Thanks a lot. bye
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: IMPORT AND EXPORT FROM ASD TO ROBOT
    10-19-2012 12:09 AM in reply to: StefanoPasquini6790
    I assume that you want to work with  ASD 2013 and Robot 2013.
    Try to start ASD and close it. Then register Robot (from Start menu) using the option indicated below running is as admin (available under the RMB):
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    StefanoPasquini6790
    10-19-2012 01:42 AM in reply to: Artur.Kosakowski
    Good morning Artur, I'm sorry but it doesn't work. I tried to do everything you say, but the result was the same.
    There is any win register key that i can modify to run correctly the ASD to Robot transfer.
    Thanks a lot.
    Product Support
    Artur.Kosakowski
    10-19-2012 02:06 AM in reply to: StefanoPasquini6790
    Start Command Prompt as Admin (from rigth hand mouse menu) then unregister and register Robot
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /unRegServer
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /RegServer
    Check the picture from the message 6 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-error/m-p/3518984/ that shows similar procedure for a dll file.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    StefanoPasquini6790
    10-19-2012 02:48 AM in reply to: Artur.Kosakowski
    Many many thanks for your easy and quick solution. You are the best...
    Grating
