• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    antoine.carimalo
    How to print cartography on big paper format
    161 Views, 2 Replies
    11-08-2012 06:27 AM
    I am trying to pring catography of the whole slab of a 35x30 meters building in plan.
    All the finite elements résults must be displayed, not only the extremums, so I need a big paper format.
    Is it possible to do that? How could I do?
    Cordially
    Antoine
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: How to print cartography on big paper format
    11-08-2012 07:46 AM in reply to: antoine.carimalo
    1. Set page size as e.g. A-0
    2. Display a map with values (or only values) selecting finite elements centers. Press Page Down severa times to reduce the size of the text as much as possible
    3. If values are not shown for each surface element use the mouse wheel to zoom in (enlarge certain part of the slab) and then refresh the view. You should have values displayed on all surface elements that are within the enlarged part of the panel
    4. Use the mouse wheel to zoom out till you see the whole panel. The values should be visible for every surface element
    5. Make screen capture either in as PNG or copy to clipboard with max. available resolution
    6. Print the screen capture from the printout composition (png) or paste the picture to e.g Paint and print from there.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    antoine.carimalo
    11-08-2012 12:00 PM in reply to: Artur.Kosakowski
    Very usefull tips ! thx so much.
