• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    How to make Excel Vba to use ARSA 2012?
    980 Views, 9 Replies
    07-21-2011 01:06 AM
    I have ARSA 2011 nad 2012 installed.
    I have an excel based vba script that does some stuff in robot.
    i added the “Robot Object Model” on the list of available
    libraries fromARSA 2012 folder.
    When I start my macro it still launches ARSA 2011.
    How could I make it to use ARSA 2012 instead?
    or choose between them?
    I have Win 7 pro 64bit and MS Excel 2007 32bit
    ARSA 2011 32bit
    ARSA 2011 64bit
    From SDK (both versions)
    Dim Robot As New RobotApplication
    Robot.Project.New I_PT_FRAME_2D
    Robot.Project.Structure.Nodes.Create 1, 0, 0, 0
    Where could I indicate which version of Robot to use?
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: How to make Excel Vba to use ARSA 2012?
    07-21-2011 05:54 AM in reply to: Priitl220
    Priit,
    Try to register the correct version of Robot before launching the script.
    Start > Programs > Autodesk > ARSAP2012 > Tools > ARSAP Component Registration
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    07-22-2011 02:41 AM in reply to: Artur.Kosakowski
    Does not work for me.
    Product Support
    Artur.Kosakowski
    07-22-2011 03:00 AM in reply to: Priitl220
    Try to unregister Robot 2011 using Start > Run
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis 2011\SYSTEM\EXE\robot.exe" /unregserver
    and then register Robot 2012
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis 2012\SYSTEM\exe\robot.exe" /regserver
    Mind to set the correct paths.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    07-24-2011 11:21 PM in reply to: Artur.Kosakowski
    I am sad to inform, that this did not work either.
    I did:
    1. Run "C:\Program Files (x86)\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unregserver
    2. Run "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /regserver
    3. Then cheked Excel VBA references . It has "Robot Object Model ver 12.0" checked (loaded from C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robotom.tlb)
    4. Then I Open C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\SDK\Samples\Silo_generation.xls
    5. And it still starts ARSA Pro 2011
    (I do not want to remove 2011 version as i need to use Revit 2011 and Robot 2011 versions also).
    Win 7 pro 64bit
    MS Excel 2007 32bit
    ARSA Pro 2011 32bit
    ARSA Pro 2012 64bit
    Should Rxcel 32 bit  be able to communicate with Robot 64bit?
    Product Support
    Artur.Kosakowski
    07-25-2011 05:34 AM in reply to: Priitl220
    Looking at the list of the application I think that the cause of the issue can be the way  WIN7 handles the registry of 32 and 64-bit applications. Please try to unregister both versions of Robot and ten register 2012. Does this help?
    If not, try to unistall 32-bit version of Robot 2011 and install 64-bit one instead. I think that for both Robot being the 64-bit applications the registration procedure should work as intended.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    07-25-2011 11:15 PM in reply to: Artur.Kosakowski
    Unistalled ARSA pro 2011 32bit
    I unregistered(/unregserver) and reregistered ( /regserver) ARSA pro 2012 64bit
    Added the “Robot Object Model ver12” on the list of available libraries fromARSA 2012 folder.
    When start sample "Silo generation" (or other) from SDK samples  i get error :Compile Error. Can't find project or library" (attached pic)
    When I close MS Excel 2007 (32bit) and reopen it has lost the “Robot Object Model ver12” from "references -VBAProject".
    Any suggestions?
    Product Support
    Artur.Kosakowski
    07-26-2011 12:24 AM in reply to: Priitl220
    This may be a problem with the  vba cache.
    Please try the following:
    1. Remove the reference to the “Robot Object Model ver12”
    2. Run “Generate Silo” (errors)
    3. Add the reference to the “Robot Object Model ver12”
    4. Run “Generate Silo”
    What is the result?
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    07-26-2011 01:10 AM in reply to: Artur.Kosakowski
    Steps that solved the issue for me.
    1. Unistall ARSA pro 2011 32bit. no change
    2. Unistall + install ARSA pro 2012 64bit. Started working
    3. installed ARSA pro 2011 64bit. Started using 2011 version again.
    4. 2011 /Unregserver. 2012 /regserver
    5. Run ARSA pro 2012, it prompts for registration of stuff.  Now it works again.
    (do not have time to try switching between them).
    Product Support
    Artur.Kosakowski
    07-26-2011 01:21 AM in reply to: Priitl220
    For the switch: mind to run unregserver and regserver as administrator (e.g. you can use Total Commander started as Administrator for this operation or run cmd.exe as administrator).
    Artur Kosakowski
    Support Specialist
    Product Support
