• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    How to incorporate rigid links correctly?
    270 Views, 1 Replies
    11-15-2012 10:18 AM
    Good evening everyone!  I'm trying to creat simple  beam model ( for simplicity's sake) which has been partly modelled using shell elements in the middle of  span and partly using a beam  elements (bars).  My question is, how correcty to incorporate rigid links between shell and bars?
    I'm attacing a picture  of model with similar concept and my own model, which does't work..
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: How to incorporate rigid links correctly?
    11-16-2012 12:15 AM in reply to: MykolasM
    You should include all nodes of the shells being in the planes of bar ends.
    Artur Kosakowski
    Support Specialist
    Product Support
