Help For Beginners
Help For Beginners
Message 1 of 15
Help For Beginners
Hi Friends, I am a new user of Robot. I am finding too many problems here. I hope somebody can help.
1.When I want to draw a floor slab, if I draw differently (clockwise or anti-clockwise, starting from longer beam or shorter beam side) it shows different maps in stresses and moments. So what is the actual method? How should I draw?
2. There are too many options. Floor, Panel, Cladding ... Inside Floor there are Shell, Deck Slab (One way), ... If I want to draw a solid floor salb which one I should use? And when I should use the others?
3. How can I design T-Beams? I mean when I set code parameters, it says that T-Beam was considered, but doesn't show any reinforcement for flanges, only shows for webs.
4. Some times when designing required reinforcement in beams, it says that for certain  beam there is "insufficient capacity against shear". Why is it happening and how to solve it? (In the attachment beam no. 33 and 66)
5. In the attached file, I drew the edge columns aligning centers, without eccentricity. But as we know in reality, it will have to be constructed with 10 cm eccentricity (ei between the centers of col. no. 5 and 17). So how should I actually draw? If I draw with eccentricity, when designing the beams, it shows a message "Segmets of the length less than 10 cm have been removed, Transfer of the RC Element has been completed". What does this mean? Is this a problem? How to solve this?
Thanks In Advance.
Replies (14)
Message 2 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Your choice. For results presentation please set correct  \ desired Direction
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-16AA1074-A4F2-4EAA-A456-86AF1F396341.htm
Rafal Gaweda
Message 3 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Floor = slab :
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-316A5523-11CC-4857-B410-649A36B19A09.htm
in short : flat horizontal panel
If you want to use such panel \ floor in desing or get results use Shell.
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-13A7E8C9-AAB0-44CE-8C48-DC9BB38...
Rafal Gaweda
Message 4 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Additional settings you have to use:
flange.jpg:
Rafal Gaweda
Message 5 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Leave it as it is or use offsets.
But before take a look at these threads;
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Beam-offsets/m-p/3332921/highlight/true#M276...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Consequence-of-axis-position-offset-excentre...
Rafal Gaweda
Message 6 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
It is caused by torsion. Turn it off.
Developers will check tosion design.
Rafal Gaweda
Message 7 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Please check your \ Robot calculations (below). Let us know if there is any bug in Robot.
Rafal Gaweda
Message 8 of 15
Thnx a lot. Now it's clear to me.
But can't ROBOT design ribbed (hollow block slab)? I see there is a tab called othographic, but even when I use that, it doesn't show the ribs in the panel thickness, or doesn't design the ribs.
Message 10 of 15
@ RG_Adsk, how can I turn tortion off, please?
Message 11 of 15
Romanich
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 12 of 15
How to turn it off?
Message 13 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
What exactly you would like to turn off? Could you quote post and lines you are referring to?
Artur Kosakowski
Message 14 of 15
Switch layout to structural model-geometry, go to design tab, required reinforcement for beam/column-option, then code parameters...
I am in the same problem where it says "insufficient capacity against shear" but the problem was still there when torsion is turned off.
Message 15 of 15
Romanich
Hi @Anonymous ,
It is hard to say what is the issue without having the model. You can zip and attach the model.
Roman Zhelezniak
