• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Harmonic Load
    174 Views, 1 Replies
    10-26-2012 01:16 AM
    Hi!
    1.-Is it possible to get the speed of the nodes in a harmonic load calculation?.
    This is possible in the time histori analysis, but for the harmonic analysis this option remains off.
    2.-How I can combine the charges if I have a Time Historty Analisys?
    Example:     1: Dead weight
                       2: Weight Machine
                       3: Maintenance Charge
                       4: Dynamic loading machine (Time History Analysis)
    Thank you for all
    Please use plain text.
    Product Support
    Re: Harmonic Load
    10-26-2012 02:10 AM in reply to: mikibierzo1973
    It is not directly output in results of harmonic analysis but amplitudes of speed in harmonic analysis can be obtained from aplitudes of displacements (displayed in for instance Displacements table) . It is resulting from the first derivative of sinusoidal function. It is enough to multiply displacements by 2*Pi*f where f is the frequency of excitation.
    Analogously amplitudes of acceleration can be obtained multiplying displacements by (2*Pi*f)^2
                       2: Weight Machine
    First converting selected time steps of time history case into simple load cases and then combining them with other cases in combinations:
    If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
