• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Ground slab Menu
    161 Views, 3 Replies
    12-24-2012 04:00 AM
    Hi everyone! Please help me to figure out the menu below:
    What does this Transversal elasticity field mean? In help section it is said that Kx, Ky are coefficients but there are values for them just at right from the input fileds. Can someone explaine it's meaning?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Ground slab Menu
    12-24-2012 04:03 AM in reply to: Ievgen
    The same as KZ but in the horizontal (along local X and Y axes of a panel) directions.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    12-24-2012 04:15 AM in reply to: Artur.Kosakowski
    So it's necessary to fill in the same value in two fields (Ky, Kx) in order to make a calclation right. And when do those values need to be changed, in which cases?
    Product Support
    Artur.Kosakowski
    12-24-2012 04:29 AM in reply to: Ievgen
    The values depend on soil parameters and this decision is going to be yours. You can use 'standard' definition of horizontal supports (nodal, linear) instead. These values matter only if you want to restrain horizontal movement of a panel due to some elastic ground conditions.
    Artur Kosakowski
    Support Specialist
    Product Support
