• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    Accepted Solution
    Geometrical imperfection
    145 Views, 3 Replies
    01-17-2013 06:35 AM
    Dear,
    I want to take into account the geometrical imperfection of some bars. The problem is that the calculation does not come to convergence.
    How can I solve this problem?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Geometrical imperfection
    01-17-2013 06:50 AM in reply to: LievenC
    My assumption is that you have non linear analysis. You may try to set the Full Newton-Raphson method (both update check boxes marked) but it is also possible that the applied load is excessive for the initially deformed structure (you may try to reduce it and check again).
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    01-17-2013 07:31 AM in reply to: Artur.Kosakowski
    Thanks, yes I have non linear analysis. Where can I set the Fill Newton-Raphson method on?
    Product Support
    Artur.Kosakowski
    01-17-2013 07:45 AM in reply to: LievenC
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-Static-Analysis-Parameters/m-p/36...
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nonlinear-analysis-Iteration/m-p/3385747
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
