• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Generation of of Calculation Model - workflow
    142 Views, 3 Replies
    09-19-2012 10:57 PM
    Hi
    I am just curios to what the best workflow is regarding the generation of the calculation model.
    Let say I do a initial calculation where I generate the calculation model.
    - Later, I add some elements such as beams and panels. Do I now need to generate the calculation model again?
    - At a later point again I add some loads. Do I now need to generate the calculation model again?
    I have read the following post: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Generation-of-Computation-Model/m-p/3362625/...
    Regarding workflow;
    Let say I am satisfied with the mesh I have currently obtained for my panel. Is it any way I can keep this mesh even if I run generation of calculation model (freeze command for instance)?
    In advance, thanks.
    Regards
    Peder
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Generation of of Calculation Model - workflow
    09-20-2012 12:39 AM in reply to: pevelor
    If you add beams or elements you need to re-generate the model.
    If you add loads you need to regenerate the model (unless they are node loads)
    As for meshing, when you are happy with the mesh select all panels and make sure mesh is frozen.
    Tony
    Valued Contributor
    pevelor
    09-20-2012 12:42 AM in reply to: tony.ridley
    Thanks Tony.
    Much appreciated
    Product Support
    09-20-2012 12:50 AM in reply to: pevelor
    Rafal Gaweda
    Product Support
