• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    SerhanB
    Generation of calculation model takes forever (API)
    317 Views, 8 Replies
    10-30-2012 09:54 AM
    Hi there,
    I'm replicating an r/c building model with Robot 2013 to see how well program performs. I successfully meshed and run analysis however the generation of calculation model takes way too much time.
    I'm meshing the model in an horizontal elements first and vertical members afterwards fashion and local meshing is done in a snap. Model generation reaches %50 in 15 minutes but takes additional 2.5 hours to reach %65 and finishes overnight. The time consuming step is "Attribute assigning (panels, solids)"
    Model is originated from revit and I put many arbitrarily placed line loads on floors... can this be the reason? Or is it just normal at that step to spend such amount of time (> 5 hours) to produce the final model?
    I've attached the model file, may be you can check that to find an erroneous thingy inside.
    Thanks for your helps
    http://www.filemail.com/dl.aspx?id=JMZHKBUKJVRGTKT
    Please use plain text.
    Product Support
    Re: Generation of calculation model takes forever
    10-31-2012 02:12 AM in reply to: SerhanB
    These can be the reasonso my suggestion is to replace 3D loads by linear on egdes (example : http://screencast.com/t/EEON097e).
    I am checking model because after 10 minutes I have 94% of model generation.
    Rafal Gaweda
    Product Support
    Product Support
    10-31-2012 09:17 AM in reply to: SerhanB
    Yes, FE linear 2p(3D) loads cause the problem ->  case 4 in this model
    Rafal Gaweda
    Product Support
    Product Support
    11-01-2012 12:14 AM in reply to: RG_Adsk
    Maybe not exaclty they but maybe their number (number of records in loads table) 961.
    Using API I have convetred and compacted them into 4 records of linear loads on egdes.
    check this model : http://www.4shared.com/zip/vJqbr_Vl/kaluga-22_5.html
    Rafal Gaweda
    Product Support
    Member
    SerhanB
    11-02-2012 08:41 AM in reply to: SerhanB
    Hi Rafal,
    thanks for your in-depth analysis of the problem. After your first post I revised the model and eliminated those line loads and issue disappeared. However in Revit I find it a breeze to place and manage line loads. I didn't understand why it’s got messed up...
    If I would have created those line loads in robot, would I have the chance to take them back to revit as editable load elements?
    Product Support
    11-02-2012 09:08 AM in reply to: SerhanB
    It is not messed up. Just every load is created as a separate record.
    Also try to avoid using non-hosted loads in revit.
    They will not be lost if you import model to revit but these loads will not be visible in it. If you export model later to robot you will see them in robot.
    Rafal Gaweda
    Product Support
    Member
    SerhanB
    11-03-2012 05:07 PM in reply to: SerhanB
    Can you share how you managed to consolidate those load entries?? You mentioned using api, did you convereted that 900+ Revit generated loads to robot native loads or kept the revit format? İ'm asking because i couldn't download and investigate the file due to an error on that site..
    Product Support
    11-05-2012 12:53 AM in reply to: SerhanB
    File here http://wtrns.fr/Fow2t7r45Mj-e52
    I will send you API macro
    Rafal Gaweda
    Product Support
    Product Support
    (API) linear load converter
    11-06-2012 02:11 AM in reply to: RG_Adsk
    Macro attached
    Due yo small bug in program the list of object is not automatically assigned to load records so it mast be done like on this example movie (of course for all these records): http://screencast.com/t/YhQkwjV9
    Rafal Gaweda
    Product Support
