• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    Generate EC wind loads by API
    214 Views, 5 Replies
    09-11-2012 01:02 AM
    I am trying to understand how to generate Eurocodes wind loads by API.
    This how I proceed:
    First I configure the project prefs
    ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "NF-EN 1991-1-3/4/NA:2007/2008")
    Then I generate the loads
            Dim SWCodeParams As RobotSWCodeECParams
            Dim SWCombEngine As RobotSnowWindEngine
            SWCombEngine = str.Cases.SnowWindEngine
            SWCodeParams = SWCombEngine.CodeParams
            SWCodeParams.StructureAge = 2
            SWCombEngine.Params.TotalDepth = 15
            SWCombEngine.Params.BaySpacing = 5
            SWCombEngine.Generate()
    I don't see how to configure SWCombEngine with SWCodeParams.
    Your help would be very appreciated. Thanks in advance.
    Francois
    Please use plain text.
    Product Support
    Re: Generate EC wind loads by API
    09-12-2012 01:36 AM in reply to: fpiedebois
    Code names are listed in this file:
    "c:\Users\All Users\Autodesk\Structural\Common Data\2013\Data\Other\norms.xls"
    so correct line should be like that:
    ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "EC1 - French NAD")
    Rafal Gaweda
    Product Support
    Member
    09-12-2012 01:51 AM in reply to: fpiedebois
    Ok for that but it does not change anything.
    I would like to change programmatically the parameters of eurocodes wind and snow loads genereation.
    If I do
            SWCombEngine.CodeParams.WindCd = 1.5
            MsgBox("WindCd " + SWCombEngine.CodeParams.WindCd.ToString)
    WindCd value still remains unchanged to 1.
    Maybe this cannot be done by API.
    Francois
    Product Support
    09-12-2012 02:10 AM in reply to: fpiedebois
    Unfortunately you are right. Due to bug in API you can not set Params, Codeparams for SW generator.
    You can only get them. I will register it for correction.
    Rafal Gaweda
    Product Support
    Member
    09-12-2012 02:15 AM in reply to: RG_Adsk
    Great, I was struggling since 2 days on it to find a solution. Do you think it can be implemented in the next update of Robot?
    Again thanks for your help, I think I will have more questions in the future.
    Francois
    Product Support
    09-12-2012 02:18 AM in reply to: fpiedebois
    workaround : RobApp.Project.Structure.Cases.SnowWindEngine.ShowParamsDlg()
    then enter these values manually in the window
    Rafal Gaweda
    Product Support
