Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Frustratin g, plastic hinges
- Highlight
- Email to a Friend
Hi All,
I tried to use the pushover at analysis with frustrating results!. I need to verify a concrete structure of an existing building. It seems not practical to use the plastic hinges in Robot.
It seems that is mandatory to specify in advance ultimate moment of the reinforced concrete sections. This may be simple for the beams but prohibitive for the columns. The variation of the compression in this case change the ultimate moment of the section. So it seems necessary define different hinges for the columns of every floor and in when the vertical action changes. In the same way considering a direction (for example x) common with lower x should have a plastic hinge different from those with greater x.
I understand also that Max and My and, more generally, the different degrees of freedom, are mutually independent. There is no possibility, therefore, take into account the biaxial moments of columns.
No one has tried to use robots in similar problems? Any suggestions?
Re: Frustratin g, plastic hinges
- Highlight
- Email to a Friend
HI Gabriele,
as it is stated in Help:
Non-linear hinges are treated as independent non-linear connections for each degree of freedom at a selected node. Interaction between different degrees of freedom is ignored.
It is limiting very strongly the practical use of this type of analysis![]()
Best regards,
Pawel Pulak
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Pawel,
thank you for your interest and sincerity. Do you think that in the future these limitations will be overcome?. As you know, today this type of analysis are more widely required by customers.
anyway thanks
- Highlight
- Email to a Friend
Hi Gabriele,
it is registered on our "to do" list with references to customers' requests concerning this feature. It also contains your
reference related to this post:
http://forums.autodesk.com/t5/Autodesk-Robot-Struc
As concerns implementation I am not entitled to inform about development plans ![]()
Pawel Pulak
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks Pawel,
I will wait confident ![]()
Gabriele
