• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Framework version 10.20 by G.M Wolsink - Robot Structural Analysis
    319 Views, 14 Replies
    04-04-2012 12:45 PM
    I have a complex model of a ship I have produced in Framework.  The file is .r3i format,
    Is it possible for me to import this into Robot so I can use this software package for the remainder of my project?
    If not, what would be the best option for transferring my data and recompiling the model?
    many thanks in advance
    Mark
    Please use plain text.
    Active Member
    Error Message when importing files
    04-04-2012 12:48 PM in reply to: 0905532
    Error message:  selected file is a file of Robot V6 program that works under DOS.
    To open this file in system conversion to the new code page is necessary
    How do I fix this?
    Active Member
    Re: Framework version 10.20 by G.M Wolsink - Robot Structural Analysis
    04-04-2012 12:52 PM in reply to: 0905532
    Also,  if starting from scratch again for my ship analysis with Robot, which 'new project' option would be best?
    quite a complex 3d model, 2000+ members.
    Product Support
    Artur.Kosakowski
    Re: Error Message when importing files
    04-05-2012 12:06 AM in reply to: 0905532
    The opening of old Robot V6 files is done in two steps. First the file is automatically converted into str format. Then you open this str file (select *.str mask in Robot's open dialog). Mind that the working language of Robot should be the same as the language of the text file you want to open.
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    04-05-2012 12:14 AM in reply to: 0905532
    Waht is \ what do you mean by framework?
    What is .r3i format? Binary or text ?
    I think you should use API to import model.
    Rafal Gaweda
    Product Support
    Active Member
    04-05-2012 04:27 AM in reply to: RG_Adsk
    framework is a free analysis package.  I am using the 3d element at the moment.  The output saves as .r3i format.
    I'm unsure if it is ninary or text...i'm assuming binary.
    What is API?
    Active Member
    04-05-2012 04:43 AM in reply to: Artur.Kosakowski
    the file i'm trying to import may not be compatible.  So how do I get a .r3i file to load on Robot?
    Active Member
    04-05-2012 04:47 AM in reply to: 0905532
    Also, I have the student version of Robot.  Does API come included? I can't see it.
    Active Member
    04-05-2012 04:54 AM in reply to: 0905532
    basically I have a large spreadsheet of data on approximately 20 different oak member types all from a historical ship which I have surveyed and modelled in detail.
    I want to transfer my timber member data into Robot as easily as possible.
    My nodes are already in place with x,y,z data.  I now want to import my members and construct the ship.
    How can I do this easily?
    Product Support
    Artur.Kosakowski
    04-05-2012 05:00 AM in reply to: 0905532
    To make sure I understand the situation correctly:
    1. It is not Robot V6 file
    2. The format is not directly supported by Robot
    What are the other formats you can save the model in the program you  used for modeling? Is it the same issue as here http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Framework-version-10-20-by-G-M-Wolsink-Robot... ? Can these posts be merged then?
    Artur Kosakowski
    Support Specialist
    Product Support
