• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    Foundation
    138 Views, 3 Replies
    01-28-2013 09:42 AM
    Hey!.
    When i cross the box for UX,UY, UZ, RX, RY and RZ i know that the spring stiffnes is not infinity but have a value. What are there values. this is for Node boundry contitions and linear boudrty conditions..
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Foundation
    01-29-2013 12:20 AM in reply to: oyvinkle
    To define an elastic support you should type values of elasticity rather than mark the given check box as shown below:
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    Re: Foundation
    01-29-2013 04:09 AM in reply to: Artur.Kosakowski
    Thanks! But I was thinking of the defult value that robot has built inn :smileyhappy:
    Product Support
    Artur.Kosakowski
    Re: Foundation
    01-29-2013 04:12 AM in reply to: oyvinkle
    There's no default value but you can use estimate it using the tool described here:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Elastic-ground-bar-definition/td-p/3760644
    Artur Kosakowski
    Support Specialist
    Product Support
