• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Footfall Analysis - Increment Number
    252 Views, 5 Replies
    09-07-2011 05:44 PM
    When you run a footfall analysis, what is the increment number?  What does it refer to?  Basically, the footfall analysis runs PAINFULLY SLOW.  Strange thing is, even if I choose to only excite ONE node, the increment number does not change.  Limiting walking frequency, number footsteps etc does not change the increment.
    I really need to speed up the analysis but am unsure how to proceed.
    Robot 2011, SP4
    6GB RAM, E8500 CPU@3.16GHz
    Please use plain text.
    Product Support
    Re: Footfall Analysis - Increment Number
    09-09-2011 02:57 AM in reply to: tony.ridley
    UNfortunatelly user is not able to control number of steps \ increments in footfall analysis. It is done automatically by program.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    09-09-2011 08:58 AM in reply to: RG_Adsk
    Rafal, thanks.  So what is your suggestion to avoid a 45 hour long analysis?
    Product Support
    09-11-2011 11:37 PM in reply to: tony.ridley
    If you do not mind please send us your model to check.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    09-12-2011 06:24 PM in reply to: RG_Adsk
    Rafal,
    My model has a Hollowcore slab in it.
    For my original footfall analysis run, I set the hollowcore to disregard stiffness in the transverse direction.
    This run gave me 2117 iterations
    Today, I turned off the disregard stiffness checkbox, and re-run the analysis.  Now I only have 100 iterations, and the analysis only takes a couple of minutes.  Can you please explain why there is such a large discrepancy in the calculation method.
    Regards.
    Product Support
    09-13-2011 12:59 AM in reply to: tony.ridley
    Tony,
    Without looking at model - number of modes?
    I can see you have subscription so if you want to check this model by my please please create Service Rerquest via subscription center or if you are from GHD I can contact you.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
