• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    AlexDT
    Accepted Solution
    Floors - span direction
    512 Views, 4 Replies
    02-28-2012 01:28 AM
    Hey,
    I've got a floor which needs to span only in 1 direction.
    I did a little test (used a hollow slab) and I get it to span in a direction, but I cant control the direction it is spanning in!
    What else do I need to do?
    The floor is carried by 4 concrete beams under every flooredge.
    Please use plain text.
    Moderator
    Romanich
    Re: Floors - span direction
    02-28-2012 01:45 AM in reply to: AlexDT
    Try to use Linear releases from menu Geometry > Additional Attributes.
    Product Support
    Artur.Kosakowski
    02-28-2012 01:55 AM in reply to: AlexDT
    You should define the directions of the slab main span and load distribution in the same way. As the one way load distribution follows the local X of the panel (I know that everybody reads help :smileyhappy:)
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-F57A58F9-81AA-4410-84EA-6BFFD83D115-214.htm
    then you should define the ortho thickness in the same way (automatic direction stands for local X of the panel as well).
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    AlexDT
    02-28-2012 02:30 AM in reply to: Artur.Kosakowski
    Thanks Romanich, but it didnt seem te make a difference.
    Artur, I changed the local x axis. That seems to turn it.
    The wiki is a lot of text and I got little time. I did got to that page, but I didnt get out of it how I could change this axis and that I had to change it.
    So sorry if I keep asking things that should be obvious!
    Product Support
    Artur.Kosakowski
    02-28-2012 02:49 AM in reply to: AlexDT
    The things seems to be obvious when you already know them :smileyhappy: Please feel free to ask all sort of questions you may have - this is what the forum is all about anyway. I'm glad that I managed to help.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
