Autodesk Robot Structural Analysis
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Floor Slab won't mesh
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
334 Views, 1 Replies
01-18-2012 07:43 AM
I've defined a floor slab as a rigid diaphragm which is supported on walls and columns. The walls will mesh but the floor slab will not. I've tried using the generate local mesh function, define the floor as a shell or a flexible diaphragm but nothing seems to work.
Any Ideas?
Re: Floor Slab won't mesh
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-18-2012 07:49 AM in reply to:
AlexOpus
Please check if you have the right panel calculation model assigned to the floor. Otherwise attach the file and indicate the panel to mesh.
Artur Kosakowski
Support Specialist
Product Support
