• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    spspro
    Accepted Solution
    Finite element mesh size
    339 Views, 4 Replies
    01-14-2013 03:06 AM
    Hello, any advice about mesh size calculating the RC panel. I tried mesh size from 0,2m to 1m and I got quite difference results, and if mesh size is small- 0,2m, I get a big amount of reinforcement, but only in a very small area (0,2x0,2m).
    What is the optimal size of mesh calculating RS panels? Thanks
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Finite element mesh size
    01-14-2013 03:34 AM in reply to: spspro
    Fine mesh is more accurate but takes longer to calculate.
    You need to find a good balance between speed and accuracy.
    igos
    01-14-2013 09:05 PM in reply to: spspro
    Hello, I'm using following rules for the RC slabs:
    a = min(2h;(1/10)*l), where
    a - element size;
    h - thickness of the slab;
    l - span of the slab.
    Also, after meshing you have to estimate mesh quality (check for triangles with acute angle and for elementswith quite small ratio = a1/a2, where a1 - the smaller dimension of element, a2 - the bigger dimension of element)
    spspro
    01-14-2013 10:56 PM in reply to: igos
    thanks igos
    igos
    01-15-2013 09:16 AM in reply to: spspro
    spspro,
    You are welcome, also I can recommend you this quite useful guide: http://www.2shared.com/file/0GSMZ7D8/How-to-Design-rc-Flat-Slabs-Us.html
