Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
File doesn´t open
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I´ve started a model "A" on a win 7 32bit computer.Brought it home , completed this model on a win7 64 bit computer.
Then, from this model "A" I created a model "B" with 40 phases (different support positions,pushed bridge), which I completed sucessfully. Then , I brought the model back the 2 models to the 32bit computer(what i have done with other models sucessfully for several times in the past). It happens now that model A opens normally while model B opens like in the screenshot atached.Title bar says it´s opened ,but main screen doesn´t show the model.Tried emptying the cfgusr folder, running it again through the manager(doesn´t work) , but it stays the same.Opening it in repair mode ,works but I loose all the phases , which was a 3 hour work And I want to avoid doing it over again.
Any ideas?
model file here, http://www.sendspace.com/file/crf9q2
Re: File doesn´t open
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have downloaded this model and opened it in 2013 SP2 64 bit version without any problems.
http://www.4shared.com/zip/b7gaBsMa/Ponte_Ptio_de_
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
estocagem_-_fase.html
Also on 32 bit was OK:
http://www.4shared.com/zip/GQqzSu8K/Ponte_Ptio_de_
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try: Tools \ Customize \ Open layouts from template or Window \ Add View \ View if you see text menu
PS.
Open the file by File \ Open rather than making double click on it or draging it onto robot window.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Open layouts from template does nothing
Window/Add view/view or table crashes the program
64 bit file you sent behaves the same way
32 bit file opens normally!!!!
thanks,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
well, your file opened ,but less than half of the phases were there ,and running the file gave " isolated nodes , and instability warnings.
thank you anyway!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So use 64 bit Robot to continue work with this model.
Rafal Gaweda
Product Support
