• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Rafacascudo
    File doesn´t open
    174 Views, 6 Replies
    10-22-2012 05:22 AM
         I´ve started a model "A" on a win 7 32bit computer.Brought it home , completed this model on a win7 64 bit computer.
    Then, from this model "A" I created a model "B"  with 40 phases (different support positions,pushed bridge), which I completed sucessfully. Then , I brought the model back the 2 models to the 32bit computer(what i have done with other models sucessfully for several times in the past).   It happens now that model A opens normally while model B opens like in the screenshot atached.Title bar says it´s opened ,but main screen doesn´t show the model.Tried emptying the cfgusr folder, running it again through the manager(doesn´t work) , but it stays the same.Opening it in repair mode ,works but I loose all the phases , which was a 3 hour work And I want to avoid doing it over again.
    Any ideas?
    model file here,  http://www.sendspace.com/file/crf9q2
    Please use plain text.
    Product Support
    Re: File doesn´t open
    10-22-2012 06:25 AM in reply to: Rafacascudo
    I have downloaded this model and opened it in 2013 SP2 64 bit version without any problems.
    http://www.4shared.com/zip/b7gaBsMa/Ponte_Ptio_de_estocagem_-_fase.html
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-22-2012 06:40 AM in reply to: RG_Adsk
    Also on 32 bit was OK:
    http://www.4shared.com/zip/GQqzSu8K/Ponte_Ptio_de_estocagem_-_fase.html
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-22-2012 06:43 AM in reply to: Rafacascudo
    Try: Tools \ Customize \ Open layouts from template or Window \ Add View \ View if you see text menu
    PS.
    Open the file by File \ Open rather than making double click on it or draging it onto robot window.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Rafacascudo
    10-22-2012 09:22 AM in reply to: RG_Adsk
    Open layouts from template does nothing
    Window/Add view/view or table crashes the program
    64 bit file you sent behaves the same way
    32 bit file opens normally!!!!
    thanks,
    Valued Contributor
    Rafacascudo
    10-22-2012 11:45 AM in reply to: Rafacascudo
    well, your file opened ,but less than half of the phases were there ,and running the file gave " isolated nodes , and instability warnings.
    thank you anyway!!
    Product Support
    10-23-2012 01:47 AM in reply to: Rafacascudo
    So use 64 bit Robot to continue work with this model.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
