FE Local coordinate system for spheric elements
Hello everybody,
can you help me with this problem: you can see in the atteched pictures that the local coordinate system of FE changes from side to side, so that local x on the left side is orientated like local y in right side and viceversa and this makes difficult to read the maps. Is it possible to have same local coordinate system?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to set the projection of the results on the global Z axis (Direction Z).
You may also set the local X of the panels in the same direction (0,0,1)
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Slab-Span-Direction/m-p/3379691
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
By setting local x (0,0,1) it works!
Thanks!
