• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Sam2M
    Export from Plant3D to Robot
    439 Views, 4 Replies
    03-03-2011 03:10 AM
    Hye !
    Plant 3D can export structure under .SDNF format.
    It seems than Robot is not able to import .SDNF format
    Any solution ?
    Thanks in advance
    Please use plain text.
    Product Support
    Re: Export from Plant3D to Robot
    03-04-2011 09:43 AM in reply to: Sam2M
    Please use SSDNF format for file type in the Open Project window of Robot.
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Sam2M
    03-05-2011 02:29 AM in reply to: pp2008
    Hi
    Thanks, I understood than .SNDF file has to be renamed to .S or .SDF to be readable by Robot.
    Product Support
    03-07-2011 12:21 AM in reply to: Sam2M
    Yes, it is necessary to change extension to *.s or *.sdf.
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Employee
    05-16-2011 12:11 PM in reply to: Sam2M
    Please watch out for this type of transfer.  I have a feeling that Plant cuts back the members for visualisation purposes which means that the members in RSA will not meet.  Easily corrected if the frame is not too large :-) Remember that Plant does not have a concept of analytical lines whereas Revit Structure and AutoCAD Sructural Detailing (to a lesser extent)do.
    Structural Techncial Specialist
    Autodesk Northern Europe
