Export drawing from Robot to ASD - 2011 versions
Message 1 of 8
Please write steps how to export drawing from robot to ASD.
 Both files of robot and ASD are open during connection.
In Robot from menu Tools/Preferences/ Printout Parameters/ Final drawing editor
I choose: AutoCAD Structural Detailing.
I opened help, there is information:
Clicking Printouts lets you choose:
  • · A final drawing editor
  • · The line thickness to be applied to printouts
  • · Whether to print the drawing in shades of gray
You can choose either the AutoCAD ® Structural Detailing editor (if installed)or the Robot editor (default) as your final drawing editor.
1)      Where to find AutoCAD ® Structural Detailing editor
2)       Please write steps how to export drawing from robot to ASD
3)       Are there needed additional installers
Direction:
ASD to Robot  I did like in this link:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Exporting-RC-drawings-details-to-ASD/td-p/32...
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check on your version one of indicated below options
Rafal Gaweda
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
BTW: You should have installed ASD 2011 on this comp.
Rafal Gaweda
Message 4 of 8
I enclose the file
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
MOvie: http://screencast.com/t/9AuVjHUa
Rafal Gaweda
Message 6 of 8
Thank You for answer
Message 7 of 8
Hi, I have Robot 2014 and ASD 2015 installed and I followed the steps mentioned to export reinforcement from Robot to ASD using the preferences dialog but I cant change the options at the Final drawing editor to AutoCad Structural Detailing. Please help
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
For Robot 2014 you need to have ASD 2014.
Rafal Gaweda
