• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    Export Steel Slap robot to Revit structure.
    212 Views, 5 Replies
    12-27-2012 04:30 AM
    Hi all.
    I is prolem.
    I design slap RC, But why I not export Steel  of robot to revit strucutre ??
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Export Steel Slap robot to Revit structure.
    12-27-2012 04:38 AM in reply to: A.wikipedia
    Please check:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/upload-slab-reinforcement-to-model-in-revit/...
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    12-27-2012 04:44 AM in reply to: Artur.Kosakowski
    Thank Artur.
    But I don't kwon Artut write : " On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
    I do not Export  ASD Reinforcement to Revit Modol???
    Product Support
    Artur.Kosakowski
    12-27-2012 04:51 AM in reply to: A.wikipedia
    It is not possible to directly export  reinforcement of slab generated in Robot to Revit but you may find the following solution helpful:
    1. Generate slab reinforcement drawing in Robot
    2. Open this drawing in ASD reinforcement and save it as dwg
    3. Link this dwg file with the project in Revit
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    12-27-2012 05:19 AM in reply to: Artur.Kosakowski
    Thank you.
    But I do not use steel of revit structure.?????
    Please see video.
    http://www.screencast.com/t/ZBMO8OtzQZh
    Thank again.
    Product Support
    Artur.Kosakowski
    12-27-2012 05:28 AM in reply to: A.wikipedia
    As you linked the 2D dwg drawing you will not be able to generate a cross section using Revit tool that is intended for a 3D model. The cross section view should be created in ASD and saved in the same or as a separate dwg file (that you link to Revit).
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
