• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    bjornhgr
    Execution problem no 902
    116 Views, 3 Replies
    04-25-2012 02:34 AM
    During non-linear analysis on a structure with planar rigid supports with released uplift, I get an error displaying "execution problem no 902". What might cause this?
    BMan
    Please use plain text.
    Product Support
    Re: Execution problem no 902
    04-25-2012 02:37 AM in reply to: bjornhgr
    If it is not the case please send us model
    Rafal Gaweda
    Product Support
    Product Support
    Artur.Kosakowski
    04-25-2012 03:40 AM in reply to: bjornhgr
    Please mind the limitations of the modal analysis for non-linear models
    See e.g. message 4 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uplift/m-p/3320823/
    also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Barre-de-treillis-traction-compression-vs-s%...
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    bjornhgr
    04-25-2012 03:49 AM in reply to: bjornhgr
    Thanks! Think I got my answer there. No good idea to combine non linear supports and seismic modal analysis. And since I'm not about to do a time history analysis, I guess that leaves me with the mentioned method of transferring results from the seismic analysis to a separate model with non linear supports.
    Thanks a lot!
    BMan
