• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    LieberSteve4929
    Error unable to find ASMm218res.​dll file
    942 Views, 14 Replies
    06-22-2012 01:07 PM
    Am getting error unable to find ./en-us/asmm218res.dll file.  This is happening when I go to import a autodesk file, the program then shuts down.  Where do I go to trouble shoot this issue?
    Thanks Steve
    Please use plain text.
    Product Support
    Re: Error unable to find file
    06-24-2012 11:55 PM in reply to: LieberSteve4929
    For now workaround:
    Copy
    c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\x64\ROReinf\ASMm218res.dll
    to
    c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US\ASMm218res.dll
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    07-11-2012 04:13 AM in reply to: RG_Adsk
    It happens the same to me,
    the procedure is correct, allows to import.
    Thanks!!!
    Technical Specialist
    Nexsys de Colombia
    Valued Mentor
    tony.ridley
    CAD import error
    07-17-2012 07:19 PM in reply to: LieberSteve4929
    Hi guys,
    I get this error when I try to import and cad file (dwg or dxf).
    Please advise........
    Tony
    Product Support
    Artur.Kosakowski
    Re: CAD import error
    07-17-2012 11:37 PM in reply to: tony.ridley
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-unable-to-find-file/m-p/3512588
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    Error unable to find file (tr-TR)
    10-05-2012 05:40 AM in reply to: RG_Adsk
    Hello from Turkey ,
    I have a similar problem ,but a little bit different.
    I am using spec editor. And I'm gonna add custom part at catalog builder . Consists of a problem at this time.
    "Unable to find " error.
    Autocad don't find  tr-TR\asmm218res.dll  , so am I.
    I can't find tr-TR folder in Program Files.
    Also, there isn't Robot structural ...... folder.!!!
    Where should I'll find tr-TR folder ?
    Product Support
    Re: Error unable to find file (tr-TR)
    10-05-2012 05:50 AM in reply to: Serdar-C
    Strange, there is no tr-TR folder becasue there is no turkish version but, create this folder:
    (W7)
    "c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\tr-TR"
    then copy contents of
    "c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US"  folder
    to this tr-TR folder
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    10-05-2012 06:12 AM in reply to: RG_Adsk
    Hello and many thanks !
    But, there is not "Autodesk Robot Structural Analysis Professional 2013 " in my Autodesk folder.
    I think this is different application for Autocad.
     Where should I create file ? Or  where should I copy this .dll ? Or which "system" folder?
    Product Support
    10-05-2012 06:16 AM in reply to: Serdar-C
    I am afraid you have posted your message to wrong forum.
    It is Robot forum, not ACAD.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    Re: Error unable to find ASMm218res.​dll file
    04-11-2013 01:55 PM in reply to: LieberSteve4929
    I have the same problem , but I could'n find the "2013" file I have instead two files "2012" and "2011" , in this two files I coudnt find  "x68" file I have instead " x86". Help plaiiiiiiiiiiiise
