• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    MohammadZaman
    Error on provided reinforcement
    216 Views, 3 Replies
    10-08-2012 12:34 AM
    Hello.
    I  have modeled and designed a multi storey concrete building.  A had model structure and soil in the same place.
    But there is a problem . When I want to transfer an element to provided module, first I can't select simple model . It's button is gray. Next when I run calculation button in provided module nothing happen. I have attached a picture and a file. Could you please help me?
    Thank you.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Error on provided reinforcement
    10-08-2012 02:52 AM in reply to: MohammadZaman
    I have restored the missing relations among simple load cases that the RC Design module needs.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    MohammadZaman
    10-08-2012 03:17 AM in reply to: Artur.Kosakowski
    Thank you . But how do you do this correction?
    Next time if I encounter with this problem what should I do?
    Product Support
    Artur.Kosakowski
    10-08-2012 04:01 AM in reply to: MohammadZaman
    Artur Kosakowski
    Support Specialist
    Product Support
