Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Error message in reinforcem ent designer
- Highlight
- Email to a Friend
- Report Inappropriate Content
I recieved this error message when running the reinforcement designer in a floor plate model. When I run model verifications there are no problems. Deflections and moments looks fine when reviewing contour maps.
Any idea what this error message means?
Jesper
Re: Error message in reinforcem ent designer
- Highlight
- Email to a Friend
Send us model please
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Rafal,
Thanks for the prompt reply. Please use the link below.
http://wtrns.fr/MLmfjn7k4HWYq94
Jesper
- Highlight
- Email to a Friend
It seems it is related to panel thickness 550cm and 700cm.
If you replace them by 80cm it is ok.
Develepers will have to look at it.
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Rafal,
Has someone looked into this as you mentioned?
If you have a look at my attachment, the slab that I'm trying to represent in Robot has a number of steps where a deep beam connects the horisontal slab. This is effectively a wall, but in Robot I have to model the FE panels in the same plane (right) and therefore I have to model them as a slab with a very high structural depth.
When I display my moments the results look OK. The problem only occur when I try to use the reinforcement designer. Is this because the reinforcement designer is only usable up to a certain slab depth? In that case how deep slabs is it ok for?
Jesper
- Highlight
- Email to a Friend
Jesper
From plate and shell theory this panel should be defined as a solid.
No, there is no such limitation in program but developers have to look at the program code to find the reason.
My guess for your reinforcement -> most likely you will get min reinforcement everywhere in these thick slabs.
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Rafal,
Why would it have to be solids and not just am FE wall?
Do you have any illustrations of how a FE slab of floor panels is joined/connected with a wall using solids?
Thanks in advance,
Jesper
- Highlight
- Email to a Friend
Jesper
I said "should".
This is the theory for Robot FEs : http://en.wikipedia.org/wiki/Plate_theory#Kirchhof
f.E2.80.93Love_theory_for_thin_plates
If you want to run RC design on this object leave it as panel \ shell. There is no significant bending in it.
Rafal Gaweda
Product Support
Autodesk, Inc.
