Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Error in reading sections data-check the sections database
- Highlight
- Email to a Friend
I just started trying out Robot. I can't seem to resolve an "Error in reading sections data-check the sections database". Any suggestions.
Bill
Re: Error in reading sections data-check the sections database
- Highlight
- Email to a Friend
Bill,
When exactly this message is displayed? The moment you start Robot? Could you make its screen capture and attach it please?
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Artur
I get the following error message after:
1. I open Robot
2. Load a project
3. Go to Geometry menu
4. Go to Properties
5. Go to Sections
6. Attempt to open a section selection from the properties database.
Bill
ERROR MESSAGE BELOW:
" See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5C257DA9-418F-11DF-BDA4-002264AF06AC} failed due to the following error: 80040154.
at DRobotSectLblMngr.frmSectionLabelManager.ComboBox1
at System.Windows.Forms.Control.OnTextChanged(EventAr
at System.Windows.Forms.ComboBox.set_SelectedIndex(In
at DRobotSectLblMngr.frmSectionLabelManager.Init()
at DRobotSectLblMngr.Main.MainOnTimer()
at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.
RobwinInterop
Assembly Version: 0.0.0.0
Win32 Version: 25,0,0,3774
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Rob
msvcm90
Assembly Version: 9.0.30729.4940
Win32 Version: 9.00.30729.4940
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt
System
Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.
AdWindows
Assembly Version: 3.2.25.0
Win32 Version: 3.2.25.0
PresentationCore
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5011 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCor
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3
PresentationFramework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationF
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.
AdApplicationFrame
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
RobwinRibbon
Assembly Version: 1.0.0.0
Win32 Version: 25.0.0.3774
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Config
Autodesk.Common.DOptionSetOrganizer
Assembly Version: 23.0.0.0
Win32 Version: 25.0.0.3756
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Window
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawin
Autodesk.Common.DOptionSetOrganizer.Resources
Win32 Version: 23.0.0.0
Autodesk.Common.DTabControlSelector
Autodesk.Common.DTabControlSelector.Resources
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility
Autodesk.REX.Loader
Win32 Version: 2012.0.0.1769
Autodesk.REX.Framework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.
Autodesk.Common.AResourcesControl
Win32 Version: 2012.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Comm
AREXRobotMngr
Assembly Version: 2012.0.0.1161
Win32 Version: 2012.0.0.1161
Interop.RobotOM
REX.Manager
Assembly Version: 2012.0.0.1769
REX.Engine
Assembly Version: 2012.0.0.1422
REX.Preferences
REX.System
REX.UI.WPF
REX.UI
REX.UI.Forms
Assembly Version: 2012.0.0.1642
REX.UI.Resources
REX.Foundation
REX.System.Resources
REX.Manager.Resources
DRobotSectLblMngr
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Vis
DRobotSectLblMngr.Resources
Interop.syspathsLib
Assembly Version: 5.0.0.0
Interop.IDbRootLib
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. "
Bill
- Highlight
- Email to a Friend
Bill,
Thank you for this information. Could you tell me what section databases are declared in your Job Preferences? Could you remove all of them but ruser (user section database) and then add them one by one to the list to see if any particular database from the original list is the cause of this situation please?
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Bill,
I have assumed you know that you can add a new section using the New Section definition icon rather than Section selection one from the database but then I realized that you actually may not know this so I decided to make this additional post. Of course the question about the list of databases you have got declared is still valid.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Bill,
Please download and install SP1 for Robot 2012 (mind to select the correct version of the pack depending on the version of Robot you have installed) from http://usa.autodesk.com/adsk/servlet/ps/dl/index?s
If you have 64-bit system you will need to install HF2 as well which will be available on this site later today or tomorrow.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
