• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    Error and the warnings messages
    361 Views, 10 Replies
    09-27-2012 09:24 AM
    Hi sirs
    I tried several times to overcome the error and the warnings messages as appeared in the structure verification window in the attached file. But I couldn’t solve them.
    Pls , could you show me how to solve them?
    Note 01 : this is apart of 21 story building but I cancelled 16 story because of file size.
    Note 02 : the attached captures showing the error and the warnings messages .
    Refaat
    Please use plain text.
    Product Support
    Re: Error and the warnings messages
    09-28-2012 08:31 AM in reply to: refaat
    I will look at it asap but in the meantime please take a look at this thread
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/meshing-error-FE-nodes-remaining-after-mesh-...
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-02-2012 01:55 AM in reply to: refaat
    Set meshing options as suggested in previous post
    Correct geometry of arc shaped walls 7340 7343 7357 7420. Each of them has bottom edge containing arc+line -> remove this line.
    Mesh model
    Because of Error object meshing  (it appears on panels 5267 5270 5272 5273 5275) select them and remesh. (Or ignore this warning because panels are meshed)
    Corrected model attached.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    10-02-2012 04:07 AM in reply to: RG_Adsk
    Dear Sir ,
    Firstly , thanks for your help , I appreciate that.
    -          (meshing options as suggested in previous post)– Pls , which previous post ?
    -             (arc+line -> remove this line mesh model.) – Pls , how can I find the lines ?
    -            If I don’t  activate the ( regular mesh ) option , will effect the FEM results?
    -          I used (Delaunay Method) ,is it okay or not ? or prefer (Automatic )  for my model?
    Concerning the warning message (The element is not assigned to any story) , does it effect the story results specially in the seismic analysis because I need some columns pass though two stories ?
    Is there any possibility to cover come the warning ?
    Regards
    Refaat
    Product Support
    10-02-2012 04:23 AM in reply to: refaat
    message 2 in this thread, then message 4 ... , I used mesh size 1m
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-02-2012 04:28 AM in reply to: refaat
    Example movie how to fined and how to "remove" it : http://screencast.com/t/Psj0u47ULb
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-02-2012 04:31 AM in reply to: refaat
    Regular (or not regular) is just different meshing algorithm. The results depends on meshing as usual - more dense mesh more accurate results, nothing extra.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-02-2012 04:42 AM in reply to: refaat
    If it is meshed without problems - it is fine.
    IN case of any problems with incoherent meshes I suggest to turn off regular meshing and use Coons because Coons algorithm is less sensitive for geometrical inaccuracies.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    10-02-2012 07:27 AM in reply to: RG_Adsk
    Pls , finally
    Refaat
    Product Support
    10-02-2012 07:39 AM in reply to: refaat
    Yes it will affect results. These columns should be assigned to upper story, in your case Story 2
     Assign them manually to story.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
