Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Error and the warnings messages
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi sirs
I tried several times to overcome the error and the warnings messages as appeared in the structure verification window in the attached file. But I couldn’t solve them.
Pls , could you show me how to solve them?
Note 01 : this is apart of 21 story building but I cancelled 16 story because of file size.
Note 02 : the attached captures showing the error and the warnings messages .
Refaat
Re: Error and the warnings messages
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I will look at it asap but in the meantime please take a look at this thread
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Set meshing options as suggested in previous post
Correct geometry of arc shaped walls 7340 7343 7357 7420. Each of them has bottom edge containing arc+line -> remove this line.
Mesh model
Because of Error object meshing (it appears on panels 5267 5270 5272 5273 5275) select them and remesh. (Or ignore this warning because panels are meshed)
Corrected model attached.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Sir ,
Firstly , thanks for your help , I appreciate that.
- (meshing options as suggested in previous post)– Pls , which previous post ?
- (arc+line -> remove this line mesh model.) – Pls , how can I find the lines ?
- If I don’t activate the ( regular mesh ) option , will effect the FEM results?
- I used (Delaunay Method) ,is it okay or not ? or prefer (Automatic ) for my model?
Concerning the warning message (The element is not assigned to any story) , does it effect the story results specially in the seismic analysis because I need some columns pass though two stories ?
Is there any possibility to cover come the warning ?
Regards
Refaat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
message 2 in this thread, then message 4 ... , I used mesh size 1m
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Example movie how to fined and how to "remove" it : http://screencast.com/t/Psj0u47ULb
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Regular (or not regular) is just different meshing algorithm. The results depends on meshing as usual - more dense mesh more accurate results, nothing extra.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If it is meshed without problems - it is fine.
IN case of any problems with incoherent meshes I suggest to turn off regular meshing and use Coons because Coons algorithm is less sensitive for geometrical inaccuracies.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Pls , finally
Refaat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes it will affect results. These columns should be assigned to upper story, in your case Story 2
Assign them manually to story.
Rafal Gaweda
Product Support
