Error 1310 while installing
Hi
I am trying to install Autodesk Robot trial on my computer but the installation fails and the following error promt is displayed:
Error 1310.Error writing to file: C:\ProgramData\Autodesk\AdLM\ASR\EMS201200F_FL_Adlm.asr. Verify that you have access to that directory.
I am the administrator of the computer and have full control of the folder. Looking into the folder I find no file with that exact filename.
Do you have any idea as to what the problem might be?
Regards
Trausti
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have you started this installation with admin rights?
(Right hand mouse click on exe, Run as Administrator)
Rafal Gaweda
I tried that yes but no luck. However something seems to be wrong with my permission settings, after using "Take ownership" on the Autodesk folder in c:\programdata the installation was able to finish.
Thank you for your reply!
