Erro nonlinear problem
athurD
Message 1 of 18
athurD
Hi.
When calculation i is problem.
Replies (17)
Message 2 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try this : http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-Static-Analysis-Parameters/m-p/36...
if it does not help please send us model.
Rafal Gaweda
Message 3 of 18
athurD
Thank you.
File modol of me.
http://www.mediafire.com/?cv1hf8c1sjg5hck
pass PM (RG_Adsk)
Message 4 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
The model you send me is linear:
Rafal Gaweda
Message 5 of 18
athurD
Sorry.
you please add the same picture.
Thanks.
Message 6 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not see any problem with Newton Raphson algorithm.
calculation times:
all cases, Newton Raphson, Sparse Solver - 2227seconds
simple cases set as auxiliary, Newton Raphson, multithreaded solver - 1700seconds - such model here :
https://www.filemail.com/dl.aspx?id=JZOUWLOFNSEKABA
Rafal Gaweda
Message 7 of 18
athurD
thank you very much.
You let me ask one question.
By my modol, then I should choose it is U + or U-?????
To get the correct results.
Message 8 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
It depends on local Z of panel
in your case U+
Examples:
Rafal Gaweda
Message 9 of 18
athurD
Hi.
I is prolem again, when change foundation raft to foundation footing???????
File modol foundation Footing. Please help.
http://www.mediafire.com/?po19hlc631a41ni
Message 10 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
No support s in UX UY directions.
I suggest you to use Automatic solver - it will report instabilities in model.
Rafal Gaweda
Message 11 of 18
athurD
Thank you reply.
I selection Automatic solver. File modol run normal.
I show deformation combo1 normal, So why Combo2,3,4,5,6,7 deformation verry max????????/. Please see picture.
Message 12 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
RG_Adsk wrote:
"No support s in UX UY directions."
It means ADD such supports.
Example below
Rafal Gaweda
Message 13 of 18
athurD
Thank you verry much.
I do not know to add ux, Uy.
Add it using the tool???
Message 14 of 18
athurD
Please guide me App support in UX UY directions same picture RG_Adsk  ???.
I desperately needed for my work.
Thanks.
Message 15 of 18
WHy are you modelling structures if you do not understand this?
Message 16 of 18
athurD
Sorry tony.
If you can tell me, I do not know what I asked.
Message 17 of 18
Rafal.Gaweda
Autodesk Support
Autodesk Support
example : http://screencast.com/t/ReS4UpwDF
Rafal Gaweda
Message 18 of 18
athurD
thank you.
