• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    athurD
    Erro nonlinear problem
    235 Views, 17 Replies
    10-08-2012 06:50 AM
    Hi.
    When calculation i is problem.
    Please use plain text.
    Product Support
    Re: Erro nonlinear problem
    10-08-2012 06:52 AM in reply to: athurD
    Try this : http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-Static-Analysis-Parameters/m-p/36...
    if it does not help please send us model.
    Rafal Gaweda
    Product Support
    athurD
    10-08-2012 07:13 AM in reply to: RG_Adsk
    Thank you.
    File modol of me.
    http://www.mediafire.com/?cv1hf8c1sjg5hck
    pass PM (RG_Adsk)
    Product Support
    10-08-2012 08:41 AM in reply to: athurD
    The model you send me is linear:
    Rafal Gaweda
    Product Support
    athurD
    10-08-2012 09:02 AM in reply to: RG_Adsk
    Sorry.
    you please add the same picture.
    Thanks.
    Product Support
    10-09-2012 02:45 AM in reply to: athurD
    I do not see any problem with Newton Raphson algorithm.
    calculation times:
    all cases, Newton Raphson, Sparse Solver - 2227seconds
    simple cases set as auxiliary, Newton Raphson, multithreaded solver - 1700seconds - such model here :
    https://www.filemail.com/dl.aspx?id=JZOUWLOFNSEKABA
    Rafal Gaweda
    Product Support
    athurD
    10-09-2012 04:27 AM in reply to: RG_Adsk
    thank you very much.
    You let me ask one question.
    By my modol, then I should choose it is U + or U-?????
    To get the correct results.
    Product Support
    10-09-2012 04:44 AM in reply to: athurD
    It depends on local Z of panel
    in your case U+
    Examples:
    Rafal Gaweda
    Product Support
    athurD
    10-09-2012 10:25 PM in reply to: RG_Adsk
    Hi.
    I is prolem again, when change foundation raft to foundation footing???????
    File modol foundation Footing. Please help.
    http://www.mediafire.com/?po19hlc631a41ni
    Product Support
    10-10-2012 12:12 AM in reply to: athurD
    No support s in UX UY directions.
    I suggest you to use Automatic solver - it will report instabilities in model.
    Rafal Gaweda
    Product Support
