• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Equivalent static analysis.
    319 Views, 5 Replies
    09-24-2012 06:15 PM
    Hi again,
    When using equivalent static analysis for EQ to AS1170.4, why can't you use the results in a combination with non linearity (ie a non-linear combination, or one that includes non-linear member properties i.e. tension only)?
    I'm thinking that the equivalent static analysis does not work correctly for models with non-linear members.  Please correct me if I'm wrong.
    Cheers,
    Tony
    Please use plain text.
    Product Support
    Re: Equivalent static analysis.
    09-25-2012 12:16 AM in reply to: tony.ridley
    Hi Tony,
    you are right - components from equivalent static analysis are ignored in non-linear combinations :smileysad:.
    Escalated to dev team. I will notify you after change.
    Pawel Pulak
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    09-25-2012 06:40 AM in reply to: pp2008
    It's important because you obviously need to add the lateral load to the gravity cases.  It's a bit useless otherwise.
    Tony
    Product Support
    Artur.Kosakowski
    03-27-2013 06:47 AM in reply to: tony.ridley
    Introduced in SP4 for Robot 2013. Please check for the availability of this update at the beginning of the next week.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    04-09-2013 08:49 PM in reply to: Artur.Kosakowski
    Robot 2103?
    I will be doing spectral analysis by telepathy by then :smileytongue:
    Product Support
    Artur.Kosakowski
    04-10-2013 12:21 AM in reply to: tony.ridley
    Corrected  :smileyhappy:
    Artur Kosakowski
    Support Specialist
    Product Support
