Envelope of forces at a connection
Konrad.O
Autodesk Support Autodesk Support
Message 11 of 11
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Envelope of forces at a connection" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Envelope-of-forces-at-a-connection-API/m-p/3...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (10)
Message 1 of 11
PaulGrimes2282
is it possible to see the envelope of forces at a point in a table? I am trying to output the maximum forces for a series of connection designs, but the envelope only gives me the maximum forces from either end of the beam.
I have tried selecting the bar and the node i am interested in, but it still gives me forces from both ends of the bar.
Thanks!
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
It was somewhere on the forum but I am attaching here xls file with macro doing that.
Rafal Gaweda
Message 3 of 11
PaulGrimes2282
thanks!
Message 4 of 11
StefanoPasquini6790
I had only ten minutes but I hope that you can develop this spreadsheet by your own.
In this spreadsheet you have to chose the Robot number, the start combination number and the end combination number and the macro define a link with robot for you needed reactions. To use only this you can set one sheet for each node that you have to investivate. Once created you linked file, when you run calculation and modify the data you have only to press F9 in excel spreadsheet to update all the values, so you create the linked file only one time.
Sorry for my basic programming but I can't make it better in few minutes.
Cheers
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 5 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Stefano,
I think your modifications were made for Grohl:
http://forums.autodesk.com/t5/robot-structural-analysis/project-octopus-seamlessly-access-robot-data...
Thx
Rafal Gaweda
Message 6 of 11
rigid_joint
Hello everybody!!!
Spreasheet node results refer to global system or to local bar axes?
Message 7 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Local.
Rafal Gaweda
Message 8 of 11
rigid_joint
I had another question.
This add-in works great with ULS and SLS combinations but as far as the ACC seismic combinations is concerned it returns no results.
Is there any trick to get over this situation?
For example, I made a try by changing the ACC type to ULS but I failed.
Message 9 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Why do you think so?
Check results for ACC combinations comparing with ULS ones.
Rafal Gaweda
Message 10 of 11
rigid_joint
Dear all, I have the same problem if there are ACC seismic combinations in the Robot file.
I get this error message when running the xls file. Is there any solution for this?
