Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Eigenvalue s
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In a dynamic calculation, what could be the main cause of this kind of message (see attached picture)
Re: Eigenvalue s
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know that my question was badly formulated.
So what is the difference between response " Yes" or "Cancel" and "No"
Somtimes, if i choose "Cancel", robot will run for a very long or endless time.
If i choose "No", will resutlts be correct and what is the difference between both choise
Regards
Re: Eigenvalue s
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Such message can be displayed when there are multiple similar eigenvalues (vibration frequencies in case of dynamic modal analysis) corresponding usually to local vibrations of some part of the structure. In such case it may happen that during iterations the order of such eigenvalues is changing and eigenvalues which were originally in the range of calculated ones will no longer be in this range. Such situation is detected by Sturm sequence check and reported as shown on the screen capture attached by you.
NO (Non) - corresponds to finishing modal analysis and passing to next load case without searching for "lost" eigenvalues
YES (Oui)- corresponds to internal increase of the range of searched eigenvalues and attempting to find the lost ones. After this increase and attempt another Sturm sequence check is done and if nothing is lost analysis is continued without any message. If some "lost" eigenvelues are still detected then this message is displayed again and further increase of the range of searched eigenvalues is possible
ESCAPE (Annuler) - corresponds to repetitive selection of YES - i.e. increasing the range of searched eigenvalues until none is "lost". In case of models containing a lot of slender bracings or other elements with local vibrations it may result in very long iterations because the number of such modes will be very high. Usually in such case these local vibrations can be ignored and there is no need to use this functionality.
If this post answer your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Pawel Pulak
Support Specialist
Product Support
