• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    bjornhgr
    Editing load cases in excel? API?
    615 Views, 11 Replies
    02-06-2012 11:35 PM
    In order to create envelope diagrams, I'm about to create separate load cases for each span of a 30-span bridge and both symmetric and asymmetric loads. Is there a way to edit the load cases i excel, or do I have to create them all in Robot?
    Thank you!
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Editing load cases in excel?
    02-07-2012 12:05 AM in reply to: bjornhgr
    You could do it in excel then export the cells to a text file.  If you rename the file as Robot text file (.str), then you can import it.
    The text file would probably look like this.................you could automate that easily in excel
    COMbination # 150 1.2DL + 0.4LL [PLAT] + 1.2LL [EQUIP] + 1.0 WIND [Z]
     ULS
    10 1.2 20 0.4 30 1 21 1.2 2 1.2 1 1.2
    COMbination # 160 1.2DL + 0.4LL [PLAT] + 1.2LL [EQUIP] + 1.0 WIND [X]
     ULS
    10 1.2 20 0.4 31 1 21 1.2 2 1.2 1 1.2
    The API guru's probably know a better way to do it though........ :smileyhappy:
    Valued Contributor
    bjornhgr
    02-07-2012 12:15 AM in reply to: tony.ridley
    Thanks. I'm not sure if we're talking about the same though. You seem to be listing load combinations whereas I'm working on load cases and Robot's "Load Types" dialog box (see image). Is your method still relevant? If so, where do I find the import function for *.str files?
    Valued Mentor
    tony.ridley
    02-07-2012 12:25 AM in reply to: bjornhgr
    well, the same would apply.
    I'd save an existing Robot file as .str so you get the format.  Then you can add your load cases......I've used the method a few times
    eg....
    LOAds
    CASe # 1 DEAD LOAD
    SELf-weight
    	1to30
    CASe # 2 SDL
     etc etc
    Then you can insert.....
    Product Support
    02-13-2012 04:54 AM in reply to: bjornhgr
    Bjorn,
    Some explanations:
    Using Excell without VBA
    - not possible to create simple case by ordinary copying by clipboard contents of excel file to robot Loads table
    - possible to add \ modify loads to existing load cases by copying by clipboard (of course cells data \ order should be the same as in robot Loads table \ Edition tab ; keep in mind that some excell cells may need to have cells format Numerical instead of General)
    - possible to create combinations this way but without controlling its number ; modification possible
    Using Excell WITH VBA
    - you can do whatever you want if you write small macro
    I am attaching simple macro to create (not modify - to do so it is needed to add some code to macro) Simple cases  - Basic tab in attached Excel file
    There is another macro on Combinations tab where you can define (not modify - to do so it is needed to add some code to macro) combinations and then generate them in Robot basing on cases from Basic tab. In this file as a default 20 cases can be used , if you need more cases - add more columns and specify correctly data in cells in row 4
    STR File:
    If you want to play with it (NOTE: not all kind of loads are supported by this format for eg panel \ countour loads) :
    - syntax described here : "c:\Program Files (x86)\Common Files\Autodesk Shared\Structural\Help\2012\R97mod01.doc"  ;
    some str file examples can be found here: c:\ProgramData\Autodesk\Examples\Example.001
    Rafal Gaweda
    Product Support
    Product Support
    02-13-2012 07:56 AM in reply to: RG_Adsk
    Small modifications in macros codes to enable modification of existing cases \ combinations.
    Excel file attached.
    Rafal Gaweda
    Product Support
    Valued Mentor
    tony.ridley
    02-14-2012 05:46 PM in reply to: RG_Adsk
    Rafal,
    As always your spreadsheets are awesome and super helpful.
    BUT:  I trialled the combination modification one last night.  I had 20 or so combinations already in my model.  There is no button on the spreadsheet to import to excel the EXISTING cases / combinations.  So I cut and paste instead.
    Then I change some factor definitions etc, then hit the button to update my Robot file.  The Combinations went completely crazy.  Some combinations that only had 3 cases ended up with 5 or 6.
    So, being too lazy / inept / bad at code to modify your sheet by myself (:smileysad:), is there any chance it could be updated to;
    1. Allow dumping the existing cases / combinations into Excel,
    2. Fix the minor bug experienced when reimporting.
    I know you just sit there all day with nothing to do anyway, waiting to write VBA for me...............:smileyvery-happy:
    Tony
    Valued Contributor
    bjornhgr
    02-14-2012 09:53 PM in reply to: bjornhgr
    Thank you for your replies! I haven't had the time to try your solutions yet, as my project stopped, but I'll give it a go as soons as I have the chance. I really appreciate this forum an all of its helpful users! Awesome stuff!
    Product Support
    02-15-2012 05:30 AM in reply to: tony.ridley
     Tony,
    You can not copy easyly combinations from Robot. Take a look at cells order in robot Combinations table:
    casenumber ; coeff; casenumber ; coeff....
    In Excel : cases are "columns" so in cells of combination rows you need only coeffs in proper columns.
    Send me beer-pack ;-)  firts
    Rafal Gaweda
    Product Support
    Product Support
    02-16-2012 12:34 AM in reply to: RG_Adsk
    Gift for You ;-) attached.
    Rafal Gaweda
    Product Support
