• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    StefanoPasquini6790
    ERROR MESSAGE WHILE CALCULATE A JOINT
    271 Views, 3 Replies
    11-09-2012 08:57 AM
    Hi everyone, is there someone that can say me why when i try to calculate a joint Robot show me this Error message. (See the attached picture)
    Thanks a lot.
    Please use plain text.
    Re: ERROR MESSAGE WHILE CALCULATE A JOINT
    11-10-2012 09:24 AM in reply to: StefanoPasquini6790
    Ciao Stefano,
    You are not the first with this problem
    here is, probably, the solution....
    Bye
    Roberto
    Moderator
    Romanich
    11-10-2012 09:48 PM in reply to: StefanoPasquini6790
    Solution in this topic
    Valued Contributor
    StefanoPasquini6790
    11-12-2012 12:01 AM in reply to: RobertoPALLADINO6546
    Ciao Roberto,
    Perfectly and easy resolved!!!
    Thanks a lot and "buon lavoro!"
