• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    aruser
    EN 1990:2002 code combinations
    218 Views, 11 Replies
    02-12-2013 04:34 AM
    I'm doing the code combinations with the automatic combinations option (EN 1990:2002 code).
    First, I have to do them with the last option called "manual combinations-generate" because the previous options are not able to performance a non linear second order analysis. Is there any way to solve this, in order not to have a huge list of combinations and just have the ULS envelope?
    Second, I only see the availability of making ULS combinations for the STR combinations of the code, what about the GEO and EQU combinations of this code??
    Third, In my strucrure, I've already done some manual combinations, now I want to have the whole code combinations...I use this tool but, in the tab "cases" i just select the simple cases, and I ensure that the manual combinations are not selected, so then, why when I go to the "groups" tab I still have the combinations? I've opened the file in repair mode but this still happens.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: EN 1990:2002 code combinations
    02-12-2013 05:03 AM in reply to: aruser
    See the attached picture. You can generate combinations using two regulations of the same type and you can select the load cases you want to include as well as the combination types you want to generate. ACC includes seismic.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    aruser
    02-12-2013 06:32 AM in reply to: Artur.Kosakowski
    Which nature should I choose for the combinations? Does this nature affects in somewhere in a certain way?
    Product Support
    Artur.Kosakowski
    02-12-2013 06:34 AM in reply to: aruser
    This is irrelevant unless you want to use one of these combinations in the definition of another combination and you care about the default load factor it should get.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    aruser
    02-12-2013 08:19 AM in reply to: Artur.Kosakowski
    Hi again,
    Going over the combinations created automatically, I've noticed that something is not going correctly.
    In the attached image you can see the EN 1990:2002 coeficientes, where for the cathegory H are empty, if empty box means 0 it would be ok...but I think it's working as if it would be 1.
    when make the combinations, this loads of the H category have to be 0 when are acommpanying the leading action.
    Active Contributor
    aruser
    02-13-2013 06:00 AM in reply to: aruser
    what I mean is as shown in the following image.
    LL E: Live load category E.
    LL H: Live load category H.
    When leading the LLE, the LLH souldn't be incluided in the combination as its acompanying factor is 0.
    So the combination should be 1,35*DL1+1,5*LLE+0*1,5*LLH+0,6*1,5*W+0,5*1,5*S
    Active Contributor
    aruser
    02-13-2013 06:11 AM in reply to: aruser
    What is the difference of this two ways? The combinations are different.CAPTURE1.JPG
    Product Support
    Artur.Kosakowski
    02-13-2013 06:53 AM in reply to: aruser
    In fact there should be two sets of ciombinatios and as far as I can see Robot creates them corerctly:
    1. E is main load so we have 0 factor for H
    1,35*DL1+1,5*LLE+0*1.5*LLH
    2. H is main load and then E get 1
    1,35*DL1+1,5*LLH+1*1,5*LLE
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    aruser
    02-13-2013 07:01 AM in reply to: Artur.Kosakowski
    The point is that Robot don't do what you and me agree:
    Robot is doing this:
    1,35*DL1+1,5*LLE+1*1.5*LLH
    Product Support
    Artur.Kosakowski
    02-13-2013 07:15 AM in reply to: aruser
    Send me your file please.
    Artur Kosakowski
    Support Specialist
    Product Support
