Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
EC7 - Geotechnic al combinatio ns
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm quoting a post from a member of the augi forum regarding geotechical checks with robot.
"i've noticed that rsap2011 for footing design does not run any analysis checks for capacity/contact surface/ stability for sliding etc for the seismic (or accidental) combinations.
Is there any implementation lack of the most recent eurocode7 version (en1997-1: 2008 )?
and what is the solution to this major issue?"
Is there any workaround for this issue.?
Maybe some modification of the file that contains the geotechnical combinations?
Re: EC7 - Geotechnic al combinatio ns
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Any advice on this issue?
How can we include ACC combinations into the geotechnical checks?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
These check are performed for SLS combinations.
If you want to use ACCidental \ SEISmic combinations for these checks you have to change their State onto SLS in rc footing module. (After importing supporting node to rc module, go to RC Element pull down menu \ Load table and then change State.)
Take a look at attached screen shot.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Rafal,
thank you very much for the response. What you propose is a solution to the problem .
I wonder if there is some way to modify the file containing the geotechnical combinations in order to avoid this manual procedure.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We split your post in to its own topic in the Autodesk Robot Structural Analysis forum where there is likely to be more active feedback on the topic.
