• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    EC7 - Geotechnical combinations
    562 Views, 4 Replies
    05-20-2011 02:08 AM
    I'm quoting a post from a member of the augi forum regarding geotechical checks with robot.
    "i've noticed that rsap2011 for footing design does not run any analysis checks for capacity/contact surface/ stability for sliding etc for the seismic (or accidental) combinations.
    Is there any implementation lack of the most recent eurocode7 version (en1997-1: 2008 )?
    and what is the solution to this major issue?"
    Is there any workaround for this issue.?
    Maybe some modification of the file that contains the  geotechnical combinations?
    Please use plain text.
    Re: EC7 - Geotechnical combinations
    06-03-2011 09:22 AM in reply to: MARIOS75
    Any advice on this issue?
    How can we include ACC combinations into the geotechnical checks?
    Product Support
    06-06-2011 02:40 AM in reply to: MARIOS75
    These check are performed for SLS combinations.
    If you want to use ACCidental \ SEISmic combinations for these checks you have to change their State onto SLS in rc footing module. (After importing supporting node to rc module, go to RC Element pull down menu \ Load table and then change State.)
    Take a look at attached screen shot.
    Rafal Gaweda
    Product Support
    06-08-2011 06:00 AM in reply to: RG_Adsk
    Rafal,
    thank you very much for the response. What you propose  is a solution to the problem .
    I wonder if there is some way to modify the file containing the geotechnical combinations in order to avoid this manual procedure.
    Moderator
    06-22-2011 04:34 AM in reply to: RG_Adsk
    We split your post in to its own topic in the Autodesk Robot Structural Analysis forum where there is likely to be more active feedback on the topic.
