Display wall length
Display wall length
TorgrimO
Display wall length
TorgrimO
Is there a way to display the length of a wall panel automatically? I can measure it manually, but this is too time consuming on larger models.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you mean generate dimension lines automatically? Could you attach some picture that shows what is your final goal please?
Artur Kosakowski
TorgrimO
I mean extracting a table consisting of panel number and corresponding distance between wall coordinates P1/beginning and P2/end.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are:
Artur Kosakowski
TorgrimO
Thanks, I forgot about that!
