Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Displaceme nt calculatio n under seismic analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ive run two seismic analysis under Eurocode 8 ; the first one with behaviour coeff = 3.90 and the second with behaviuour coefficient = 1.00 ; ive got slitly the same results in term of displacement at the stories table.
so , Please confirm that the displacement calculated at the stories table are the elastic one , and they should be multiplied by the behaviour coefficent in order to the obtain the correct ones when doing seismic analysis ( with behaviour coefficient greater than 1.00)
In advance Thank you.
Re: Displaceme nt calculatio n under seismic analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Displacements in EC8 are in case of design spectrum already multiplied by behaviour coefficient q.
In case of T>TB it results (independently from q value) in displacements equal to displacements from elastic spectrum.
If some vibration modes with significant mass participation are observed for T<TB it may result in slight differences of displacements depending on q value - as it the screen captures attached to your post.
This effect results from comparison of analogous branches of elastic (formula (3.2)) and design (formula (3.13)) spectrum - the difference between them is more than just division by q, as in other branches of spectra.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi pp2008,
regarding "Displacements in EC8 are in case of design spectrum already multiplied by behaviour coefficient q."
This is a valid statement only for stories tables or also to nodal displacements table and diagrams for bars (deformation) ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, it is a valid statement also for nodal displacements and diagrams for bars.
Pawel Pulak
Support Specialist
Product Support
