• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    faisal.aaouatif
    Displacement calculation under seismic analysis
    490 Views, 3 Replies
    01-30-2012 08:55 AM
    Ive run two seismic analysis under Eurocode 8 ; the first one with behaviour coeff = 3.90 and the second with behaviuour coefficient = 1.00 ; ive got slitly the same results in term of displacement at the stories table.
    so , Please confirm that the displacement calculated at the stories table are the elastic one , and they should be multiplied by the behaviour coefficent in order to the obtain the correct ones when doing seismic analysis ( with behaviour coefficient greater than 1.00)
    In advance Thank you.
    Please use plain text.
    Product Support
    Re: Displacement calculation under seismic analysis
    01-31-2012 09:25 AM in reply to: faisal.aaouatif
    Displacements in EC8 are in case of design spectrum already multiplied by behaviour coefficient q.
    In case of T>TB it results (independently from q value) in displacements equal to displacements from elastic spectrum.
    If some vibration modes with significant mass participation are observed for T<TB it may result in slight differences of displacements depending on q value - as it the screen captures attached to your post.
    This effect results from comparison of analogous branches of elastic (formula (3.2)) and design (formula (3.13)) spectrum - the difference between them is more than just division by q, as in other branches of spectra.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Active Contributor
    RRufino
    02-01-2012 03:40 AM in reply to: faisal.aaouatif
    Hi pp2008,
    regarding "Displacements in EC8 are in case of design spectrum already multiplied by behaviour coefficient q."
    This is a valid statement only for stories tables or also to nodal displacements table and diagrams for bars (deformation) ?
    Thanks.
    Product Support
    02-01-2012 04:25 AM in reply to: RRufino
     RRufino:
    Yes, it is a valid statement also for nodal displacements and diagrams for bars.
    Pawel Pulak
    Support Specialist
    Product Support
