• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Dimension precision when exporting to Robot using API
    178 Views, 14 Replies
    02-21-2012 03:13 PM
    I have a macro to export a model from cad to Robot using API.
    I would like to know what is the criteria that Robot uses to round the dimensions of elements that came from cad.
    I have this doubt because I've noticed that all the dimensions in cad have more decimal places than the dimensions in Robot.
    Any help will be appreciated.
    Distinguished Contributor
    tony.ridley
    Re: Dimension precision when exporting to Robot using API
    02-21-2012 06:37 PM in reply to: LuisCRodrigues
    you know you can change the number of decimal places under preferences?
    or, just open the dwg from within Robot
    tony
    Product Support
    02-22-2012 01:08 AM in reply to: tony.ridley
    Additional remark related to DXF or DWG import:
    When model is imported from DXF or DWG in metric units the coordinates are rounded off to 4 decimals. It results in higher precision when importing in millimeters than when importing in meters.
    Best regards,
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    02-22-2012 06:38 AM in reply to: pp2008
    Maybe I was not clear: I'm using Robot API.
    For example:
    If I have a line in cad, my macro reads the coordinates of the end points and creates two nodes in Robot with the same coordinates. Then a bar is created using these two nodes as startnode and endnode.
    My problem is that the coordinates that are read in cad have more decimal places than the coordinates that are written in Robot.
    I need to know how Robot rounds the coordinates that receives using API.
    Product Support
    02-22-2012 08:19 AM in reply to: LuisCRodrigues
    Take a look below:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    02-22-2012 09:19 AM in reply to: RG_Adsk
    I obtain a different result.
    Do you know why?
    02-22-2012 02:33 PM in reply to: RG_Adsk
    Rafal,
    Meanwhile, I've made some tests.
    I have exported from excel to robot different nodes with different coordinates and I'm getting different results.
    It's still a mistery (for me) what's the criteria that Robot uses to round the coordinates.
    Product Support
    02-23-2012 02:06 AM in reply to: LuisCRodrigues
    Luis
    It seems robot reads up to 9 digits after comma (in meters) in API.
    I had 10 digits yesterday but I do not know how it happend. Today always 9.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    02-23-2012 02:22 AM in reply to: RG_Adsk
    I'm using Robot 32 bit with Windows XP 32 bit and Windows 7 32 bit.
    I don't know if this is important, but the code that I've made for exporting from cad to Robot is used by some users.
    Some of them uses Windows 7 64 bit.
    Product Support
    02-23-2012 02:46 AM in reply to: LuisCRodrigues
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
