• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Accepted Solution
    Diagram for walls
    295 Views, 6 Replies
    12-04-2012 04:43 AM
    Hi
    I want to use a diagram illustrating the vertical load applied to a wall.
    So far, I have only been able to use maps and thick of membrane forces.
    Moreover, I want to find an average value or integral value.
    Can someone please help me with this?
    Kind regards
    Peder
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Diagram for walls
    12-04-2012 04:59 AM in reply to: pevelor
    Peder,
    Could you attach a sketch which illustrates what the diagram should look like please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    pevelor
    12-11-2012 02:57 AM in reply to: Artur.Kosakowski
    Hi
    I diagram looking like this would be nice
    Is that possible?
    Regards
    Peder
    Product Support
    Artur.Kosakowski
    12-11-2012 04:11 AM in reply to: pevelor
    Here you are.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    pevelor
    12-12-2012 01:00 AM in reply to: Artur.Kosakowski
    Thanks Artur.
    Would it be to much to ask if you could make a short video illustrating how you would do this in structure type 'Building design'?
    One reason I want to check these values is to investigate the minimum thickness of a wall in regards to just compression.
    Product Support
    Artur.Kosakowski
    12-12-2012 01:16 AM in reply to: pevelor
    Here you are.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    pevelor
    12-12-2012 02:02 AM in reply to: Artur.Kosakowski
    supernice.
    Thanks a lot
