• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    andrea.pontiggia
    Accepted Solution
    Design of inclined elements
    173 Views, 1 Replies
    02-25-2012 12:39 AM
    hi, I wanted to know if there is a way to export the designs of the armor elements inclined Robot, also with AutoCAD Detailing. Thanks in advance
    Andrea
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Design of inclined elements
    02-26-2012 11:46 PM in reply to: andrea.pontiggia
    The inclined beam reinforcement export to ASD is not supported. You can try the following solution:
    Window > Add View > Beams > Beam Reinforcement Edition  and save the generated drawing as dxf/dwg
    Mind that this is going to be an ASD file but a vanilla AutoCAD dwg instead.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
