Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Also, you can use shells for column:
Roman Zhelezniak
Sorry, but I didn't understand your idea.
Also, if you want use tapered bar with one vertical flange, try to use Offset option. But note, as an Artur wrote - bar element is just the line that represents the center of the section with assigned attributes such as profile type.
Roman Zhelezniak
Thanks You Romanich
Hi. You can toturial creative frame same picture???
Please tutorial video. Thanks you verry much
HI thank you very much but i think steel in message 4 modeling as solid ??
i use method in message 10 in link below
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Column-with-section-change/td-p/3434495
please help me thank
modeling column steel in industrial building
